Plex library issues
Solved by Donut417,
1 hour ago, Lurick said:You could run a DB check and, if needed a repair as well. I had my DB get corrupted recently and this tool worked perfectly:
Thanks for the suggestion. It didnt fix the issue. What I ended up doing is deleting the entire TV library and resetting that up. Once I did that and it started grabbing media and meta data and it seems to be fixed now. Not sure if it was a database issue or something else.
