Should i plug my PSU directly into the wall or a surge protected extention cable?
Solved by Dedayog,
5 minutes ago, IR76 said:With how demanding PSUs can be I'm not sure if it is safe to use a surge-protected extension cable as it may not be able to meet the demands?
What demand? That line of thinking isn't a thing.
Use a surge protector, it may or may not protect with a lightning strike or power outage spike but it's better than nothing.
