Move Reserved partition to allocate space for C:
Solved by Eigenvektor,
6 minutes ago, Murasaki said:Uh.. can't you move C to the left once and then the Unallocated to the right to align them?
You can't move the partition your currently running OS is on.
Best bet would be to use e.g. a live-USB image of GParted.
Just be sure to backup important stuff before messing with anything.
Personally I don't think adding another 16 MB is worth the risk. nm, saw there's another 5 GB there...
