Thin Rad + Push / Pull vs Thick Rad Single Fan
Go to solution Solved by emosun,
2 minutes ago, ChrisLoudon said:
Thanks for the reply.
This is my bedroom PC so chances are a warm room when it comes to ambient temp (21C). 4090 + 13600 OC'd.
Acoustics aren't of huge importance as I don't have it on when I'm using it but my girlfriend might be in bed reading whilst I'm gaming with my headphones on so not wanting it to sound like a damn hairdryer.
C
then in that case just run less fans at a higher speed. if the fans are at a decent speed then you don't need a push pull config.
Hi guys,
Pretty simple question but what is likely to perform better between a thin rad with fans in push / pull or a thicker rad with a single bank of fans.
Build is gonna be in an o11 D XL EVO with EKs Quantum Surface Rads and Lian-Li Uni 120 fans.
I have a choice between a 360S with 6 fans for both the top and bottom or go for the thick boy 360X with 3 fans.
Cheers
C
Bedroom PC - Lian-Li O11 XL Evo - Intel Core i5 13600k @ 5.4P / 4.4EGhz -  MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - Gigabyte RTX 4090 - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Living Room PC - Hyte Y60 - Intel Core i9 9900k @ 5Ghz -  MSI Meg Ace Z390 Mobo - 16GB Ram - Palit RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i7 8086k @ 5.1Ghz -  Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - EVGA RTX 2080ti - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office - Thermaltake Tower 100 - Intel Core i7 8700K @ 5.1Ghz - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - EVGA GTX 1080ti - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU + GPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Annex - Corsair 250D - Intel Core i7 3770k - Asus P8Z77 I Delux Mobo - 16GB Ram - EVGA GTX 980ti - 256GB Corsair SSD - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Office - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 980 - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 15TB Storage Server
Living Room AV Setup 5.1.4 - Yamaha RX-A2060 - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Yamaha RX-A1070 - 5 x Monitor Audio C265s (2 Zones)
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
it would depend on the air temperature , and fan speed
lot of people aren't aware that sometimes water cooling isn't even any better than air cooling if the air temps are poor. basically an air cooler that has cold air works better than a water cooler using hot air.
also if you have the fan speed set too low becuase the machine is directly next to the actual station the person sits at and they want less noise , then it'll run hotter as well.
Do you plan on running the machine with decent fans speeds in a climate controled room?
C
C
Cheers!
I personally think thinner rad with higher fin density is better than a thicker rad with fewer fin density for cooling performance, but could be noisy. Maybe its the other around for something more quiet, but would require more radiators if you were trying for something more towards silence.
CPU: AMD Ryzen 9 3950X   Motherboard: MSI X570 Gaming Edge Wifi   Case: Deepcool Maxtrexx 70   GPU: RTX 3090   RAM: Corsair Vengeance LPX 3x16GB 3200 MHz   PSU: Super Flower 850W
hard to say thin can be good with 25mm+ fans a mid size say 45mm rad meh not much but a 60mm rad can also be good. but advoid thin fans when posable like 15mm fans... i would do a thiner rad with 25mm fans in that case.
some thicker rads then 65mm+ might need better fans and posably push pull but doing push pull on thinner rads is a wast of money. maybe if there cheap fans then w/e.
cheaper fans work better on thinner rads too.
buying 2 thinner rads vs one thicker rad is also better if you have space form em.
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
Thanks for the info.
Doing a bit of a weird dual loop build in an O11 D EVO XL.
Got a Quantum Surface S240 on the rear of the case. Kinda push / pull but only single Uni Fan SL-INF holding it to the case but 2 of them on the inside surface.
With the Mobo tray dead centre, in the bottom I can get a EK QS S360 with 6 x Uni Fan SL-INF in push / pull or an EK QS X360M with 3 of them just pulling. I'm not sure about the top of the case yet as I'm still waiting for the upright GPU bracket kit to arrive and I don't know how it mounts to the case and what options are available. It all depends on how much of the GPU is gonna be obscured by a rad at the top.
