What is a vertical fan position
Solved by Dedayog,
4 minutes ago, LOST TALE said:"Mounting: Sleeve fans are best mounted in a vertical position due to their lubricant system. Sleeve fans can be mounted in any axial orientation, of course, but will 'wear out' more rapidly when mounted horizontally."
Is vertical when he fan is moving air horizontally?
Correct. Vertical mounting is the fan up and down, like you stand.
Horizontal mounting is like you laying down.
