How many fans can I daisy chain together
Solved by TVwazhere,
16 minutes ago, NewbiePeyton said:So I have a Asus prime b760-plus d4 and I have 8 fans (including cpu cooler) and I’m wondering if I need a rgb hub or if I could just daisy chain them all together and plug into motherboard
There's a technical answer to this:
Each fan header on a motherboard is able to push out (typically unless otherweise specifed) 1A of power.
Every fan has their listed amp usage on them. Typically this ranges from 0.15A to 0.4A. You can find this info on the fan motor sticker
So, generally speaking you can safely attach 3 fans to one header. Beyond that, you'll need to invest in a fan hub to get the amount of fans you want all controlled by one header.
