7700x 7800xt AMD in a Lancool 216 Air flow case
strat guy
Lian Li Galahad 360 CLC/AIO
Lian Li Lancool 216 "Air Flow Focus" case
Gigabyte B650 Aorus Elite AX
Gigabyte 16x4 Aorus RAM
CM 800 watt something PSU
Samsung 980pro OS and a couple of 4 and 6 TB mechanical
1440p res @ 144hz monitor, LG something running free sync.
Shame about the grainy pics, tsk.
I think it's allrite though, should last a good couple years and then some before it starts ageing on me.
  • 2 weeks later...
you can take a pic on the pc with the print screen button. then open up paint and ctrl v to past it then upload it here 🤷‍♂️
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
