So I’m getting a new monitor at a $200 to $250 price range. It’s for gaming and watching movies. I’m not too snobby about the color accuracy or black levels and that stuff because I’m upgrading from a crap monitor. I would be fine with a 144hz or 240hz, and I’m fine with 1080p but would prefer 1440p. Also an ips panel is my first choice. The two I’m looking at right now is the Samsung LS27BG402ENXGO and the LG 27GN800-B. I’m open to a completely different monitor if those aren’t good choices. Thanks
https://linustechtips.com/topic/1542143-help-choosing-between-two-monitors/
if this is the us, the best deal right now is this one
https://www.amazon.com/gp/product/B0B18HWB9M?smid=A1HMEUY6L6RX3B&th=1
it's the same panel of one of the wide-gamut msi monitors.
if you dont want ktc then this one is better than the LG you linked
https://www.amazon.com/LG-27GL83A-B-Ultragear-Compatible-Monitor/dp/B07YGZL8XF/?_encoding=UTF8&pd_rd_w=JWKo4&content-id=amzn1.sym.ca151083-166b-424a-8d3d-e2c1b10c2844&pf_rd_p=ca151083-166b-424a-8d3d-e2c1b10c2844&pf_rd_r=EPYSSBJ9ZHBKQWY4F18X&pd_rd_wg=hoEFf&pd_rd_r=a06ed119-9c2e-4d2a-a9bc-ec48127a35db&ref_=pd_gw_dealz_m1
Even though the samsung is 240hz, the color coverage is subpar, sorta a tradeoff at that pricepoint for 240hz
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
The LG 1440p and same panel type. 144hz and 240hz is not as game changing as coming from a 60hz monitor to 144hz monitor. LG is the better choice out of the two. I believe you'll be happier with the LG as 1440p IPS 144hz.
Coming from some one who was once on a 1920x1080 24" 75hz TN panel for 3 years.
First watercooled System
Build Name: White Knight
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: Corsair Clear
PSU: Lian Li Edge 1000W
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: Beacn Mic
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS/Gamer Advantage Liquid
Camera: Razer Kiyo Pro/OBSBOT Meet SE
