Looking for a soundbar recommendation for my parents
You'll want something that has at least 3 channels. With a soundbar that has 3 or more channels, the dialogue plays through the center speaker and everything else (music, sound effects, etc.) is separated and played through other speakers on the soundbar. Sonos Beam fits that description and is within your budget, but the lack of a subwoofer is not ideal at that budget. Your local Best Buy more than likely has some good deals on open box Soundbars. Just because they're open box doesn't mean that they're damaged or won't last as long, it just means either it was previously a display unit or someone returned it and Geek Squad tested it to make sure it works. That being said, ALWAYS insist they plug it in and try it to make sure it works properly before buying it. If they're reasonable employees, they won't mind doing this. When I worked at Best Buy my managers said to stop offering to do so because it took time away from me selling more memberships and credit cards but most of the employees aren't corporate slaves unless you're dealing with one of the managers. If there's no Best Buy near you, I would check ebay or other used product websites/apps and look for older models of soundbars that still support eARC (the standard that all modern TV's use for audio). As long as it has 3 channels or more and a subwoofer (3.1, 5.1, etc.) and comes with all the power cables necessary, you've more than likely got a huge upgrade to the TV speakers. Some brands that are my favorite for that budget are JBL, Samsung, Sony, and Polk Audio. Brands I would stay away from unless you find a REALLY good deal are Vizio, TCL, and Hisense. Bonus if the soundbar supports Atmos, you'll be able to tell because there will be 3 numbers when it comes to channels instead of 2, the third number being how many upward firing speakers there are (ex: 3.1.2). Just gives even more separation of sound for TV's and sources that support it. Hopefully that helps, let me know if you have any questions or want any specific recommendations when it comes to specific models
