Wired earbuds for gaming?
Soujiro1337
Due to a medical condition, I am unable to use over-the-head headsets. Any recommendations?
Currently looking at Logitech's G333, but wanted to check here before making any purchases...
Apple earpods. They are dirt cheap and good.
The logitechs are super genric and you can get great stuff for that price
in ear buds?
Why go for a gaming(/PC) brand and not an audio brand?
Like https://www.amazon.com/SE215DYBL-Isolating-Earphones-Translucent-Microphone/dp/B08G4GZ3QV/
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
How are you putting "Apple" and "dirt cheap" in the same sentence?
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
https://www.amazon.com/Apple-EarPods-3-5mm-Headphone-Plug/dp/B06X16Z7DZ/ref=sr_1_3?crid=10JZAKRRCXQCJ&keywords=apple+earpods+3.5&qid=1696853703&sprefix=apple+earpods+3.5%2Caps%2C160&sr=8-3
And that is from apple 3rd party sellers it's 10 for official ones
4 minutes ago, jaslion said:
lol, there is a reason they are so cheap. 😉
But if they work for you hey, good for you.
OnePlus:
Other Tech:
3 minutes ago, Dedayog said:
Oh no those are fake ones.
Those are trash.
They are a solid 7/10. Which is basically same as the logitechs 😛
Oh yes that i can fully believe!
Thats also why i asked why go for a brand like that and not some that actually does audio well. 😄
I agree, but sub-$20 can be easier to swallow than almost $100 for a lot of people.  Think that's the bigger issue for most.
OnePlus:
Other Tech:
9 minutes ago, Soujiro1337 said:
I went for gaming because of what brands I'm used to, but these seem great! Thanks for the recommendation.
What's the budget?
~20$ => QKZ x HBB or the 7HZ Salnotes Zero
~50$ => Truthear Crinacle Zero
~130$ => Simgot EM6L
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
7 minutes ago, 191x7 said:
What's the budget?
Since these are going to be semi-permanent, gonna be using them for a couple of years maybe, budget is high. 100+ is fine, as long as they are good, wired and have microphone.
The EM6L look nice but don't have incorporated mic...
The point of these is to add your own mic as they have detachable cables
There's also the Kiwi Ears Orchestra Lite, those are about $250.
There are even pricier (and better) options, but going above $250 is not something I'd do so I don't usually recommend it.
This is true. All of them have detachable 2-pin cables and one can add a cable that has a microphone built-in.
Or, the better option, use a desk microphone. There are plenty to choose, even in the sub %50 range.
Thank you all for the help, it was very informative! Cheers
On 10/9/2023 at 7:01 AM, 191x7 said:
What's the budget?
Truth ear nova is coming soon and is said to be almost as good as the blessing by the people who tested it pre release
