So I need a computer that is capable of running programs like Maya, 3Dmax, Inventor 2015.For about $1200 AUD
What do you think about this? I already have a monitor ecc...
CPU:  Intel Xeon E3-1220 V3 3.1GHz Quad-Core Processor  ($245.00 @ CPL Online)
Motherboard:  Asus H81M-E Micro ATX LGA1150 Motherboard  ($62.00 @ CPL Online)
Memory:  G.Skill Value 16GB (2 x 8GB) DDR3-1600 Memory  ($175.00 @ CPL Online)
Storage:  Samsung 840 EVO 120GB 2.5" Solid State Disk  ($99.00 @ PCCaseGear)
Case:  Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($69.00 @ PLE Computers)
Total: $709.00
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-05-17 00:52 EST+1000)
SuperNova: CPU: Intel Core i5 4670k @4.6 GPU: Sapphire R290 Tri-x @1200, @1350, MOBO: MSI Z87 G45 Gaming, RAM: 16Gb HyperX Fury White @1866, PSU: CORSAIR TX750M, CASE: Arc Midi R2, SSD: Kingston 120gb SSD,
COOLING:
H100i w/ 2x Nb eLoop 800rpm
Check out my build log Black Dawn Check out my build log Supernova
https://linustechtips.com/topic/153095-light-3d-modelling-machine/
why a quadro? just get normal GTX and get more CUDA cores for faster processing, especially if this is not a rig that would be doing rendering 24/7
(and even then ive had many projects where the final render took up to a week and never was a 770 to blame for any faults)
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
Well I have a 780 under water already. Should I just use my rig?
COOLING:
Not very good for Maya Check out this table here to compare differnet workstation cards, there are a few gaming cards thrown in for comparison too
http://www.tomshardware.co.uk/specviewperf-12-workstation-graphics-benchmark,review-32929-9.html
well if it has a capable CPU yeah. unless you render on the CPU tho, an i5 is plenty capable to run maya and the likes
Oh wow. The 780ti destroys everything. I'll just stick with my current rig then ;)
COOLING:
Exactly :) Workstation cards really should only go on workstation computers and only if the company is paying ;)
If you wanted more compute performance you could always get a Titan black instead, then keep one rig for gaming AND modelling
yes and this is an anomaly or BS numbers from tom's hardware (once again) the 780ti won't even have double point precision calculation, the quadro K6000 is a 12gb graphics card and will be running LAPS around the 780ti in maya an any 3D rendering soft.
THAT BEING SAID such a card worth well over 5000$ so YES just stick with the 780 you ALREADY HAVE...rest of the build is flawless i would have suggested the exact same thing, maybe 16gb of RAM though..and a 240GB SSD.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
Total: $709.00
Light 3D modelling is in the realm of Quadro K2000... K4000 is too expensive for light usage.
yes and this is an anomaly or BS numbers from tom's hardware (once again) the 780ti won't even have double point precision calculation, the quadro K6000 is a 12gb graphics card and will be running LAPS around the 780ti in maya an any rendering soft.
THAT BEING SAID such a card worth well over 1500$ so YES just stick with the 780 you ALREADY HAVE...rest of the build is flawless i would have suggested the exact same thing, maybe 16gb of RAM though..and a 240GB SSD.
That depends in compute heavy tasks the quadro will destoy the 780ti, for example here in solid works, but programs like Maya, and for light rendering tasks a Quadro is a very expensive thing to justify
http://www.tomshardware.co.uk/specviewperf-12-workstation-graphics-benchmark,review-32929-17.html
But if a 780ti can still handle the task ok even if not the fastest its hard to justify a whole second PC with a 1500$ card if  the workload is only light.
Depends on the workload
that i have to agree with but the numbers shown in the first bench from Tom's are not from this world, no way a 780ti will outdo a fully enabled quadro K6000 GK110 GPU that has been cherry picked for being top of the line and paired with the highest quality GDDR5 12GB of VRAM in ANY situation, no way.
the titan did well?, I agree it will not out do a K6000, but its 1/3 the cost
http://www.pugetsystems.com/labs/articles/AutoDesk-AutoCAD-2014-Professional-GPU-Acceleration-504/
well the K6000 is GK110 with unlocked double FP and ECC memory. of course it will be faster
OP...i just came to realise that the CPU you've picked DOES NOT OFFER HYPERTHREADING, consider to upgrade it to the xeon E3-1230v3 it won't cost much more but will process almost double the data cause it is hyperthreaded...
Strange here toms shows completely different results. Is this because the old version performs differently?
http://www.tomshardware.com/reviews/geforce-gtx-780-ti-review-benchmarks,3663-12.html
no, it's because tom's is shit, never trust any of their benchmarks.
that value ram is costing u much more than actual...
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231637
that ram is terrible, not heatsinked, 11 latency...terrible product that should not even exist
This is good RAM for the price:
http://au.pcpartpicker.com/part/kingston-memory-hx316c10frk216
Here op, revised build, much better, go with your 780 and this kit, if over budget go with 120gb SSD
and if still over budget put back the shitty PSU you selected in the first place it will get the job done:
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU: Intel Xeon E3-1230 V3 3.3GHz Quad-Core Processor ($295.00 @ PCCaseGear)
Memory: Kingston Fury Red Series 16GB (2 x 8GB) DDR3-1600 Memory ($179.00 @ PCCaseGear)
Storage: Kingston SSDNow V300 Series 240GB 2.5" Solid State Disk ($149.00 @ Mwave Australia)
Power Supply: Antec High Current Gamer 520W 80+ Bronze Certified Semi-Modular ATX Power Supply ($99.00 @ CPL Online)
Total: $853.00
(Generated by PCPartPicker 2014-05-17 01:37 EST+1000)
Total: $709.00
I would go for a laptop to be honest.
It would be so much lighter than a full desktop with sepperate monitor.
he already has a monitor as stated in original post and did he mentionned having to carry the thing on his back all day long? WTF !
I would do the rendering and modeling by hand in a sketch book that way you won't need a computer...?! WTF WTF WTF
EDIT: OP read through PAGE 1 carefully all your answers ARE THERE!
I would do the rendering by hand on a sketch book that way you won't need a computer...?! WTF WTF WTF
He is asking for a light 3d modelling machine. A full desktop will weigh more than a laptop.
but then its overly expensive and not as good at rendering...
But a laptop is much lighter than a desktop. He could use a remote server to do any calculations or simulations that he needs.
light as in no heavy tasks like 1 week render times...
