But a laptop is much lighter than a desktop.
AHAHAH very funny sir!
please tell me you are intelligent enough to realise that the RENDERING to be done is LIGHT, not that the MACHINE has to be LIGHT !!
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
But a laptop is much lighter than a desktop. He could use a remote server to do any calculations or simulations that he needs.
Or just buy a good desktop PC that will serve him much better and call it a day, now please...go on.
Ahahaha I laughed more than I should've. I'll just stick with my rig then ;) and maybe get another 780 with the money I have.
SuperNova: CPU: Intel Core i5 4670k @4.6 GPU: Sapphire R290 Tri-x @1200, @1350, MOBO: MSI Z87 G45 Gaming, RAM: 16Gb HyperX Fury White @1866, PSU: CORSAIR TX750M, CASE: Arc Midi R2, SSD: Kingston 120gb SSD,
COOLING:
H100i w/ 2x Nb eLoop 800rpm
Check out my build log Black Dawn Check out my build log Supernova
make sure you check the one i posted on page 1 op...it has many upgraded parts you should consider...mostly the hyperthreaded xeon CPU!
