Missing pin on PSU cable
Solved by seon123,
2 minutes ago, Irafli said:Image 2: molex cable
The PSU side of the cable likely has a 3.3V pin, which is not used on Molex connectors.
4 minutes ago, Irafli said:Image 3&4: PCIe 6+2 to PSU cable, PSU end cable have the missing pin
PCIe connectors have 3 12V pins, the PSU side has 4 12V pins.
4 minutes ago, Irafli said:Image 5: 24 pin cable
The -5V pin has not been used on PSUs for about 20 years.
