Help planning a PC build for school / later gaming.
6 minutes ago, Kanna said:From what I heard, AMD was supposed to be better at utilizing in this area though? But could have changed? as for the other parts I looked them up and some of them were available, but the motherboard and PSU wasn't, and the SSD 2TB version wasn't available either. but I managed to get my budget down some while still mostly being this config I suggested still.
Okay, thats possible that AMD is better in that regard... But still i would make some chjanges about your build.
1 hour ago, Kanna said:
The Mainboard is BAD, it MIGHT work with a 7700X but its literally the worse Board that hardware unboxed testet in their B650 round up.
I would highly suggest you go with the TUF gaming wifi(https://www.dustinhome.se/product/5011308282/tuf-gaming-b650-plus-wifi) which is a much better board and not to much more at the shop you linked. And the other bigger concern would be the RAM i would go with at least something like 6000MHz as i assume that the work tasks would benefit from faster RAM... If you are willing to drop the RGB this is a nice Kit and even a bit cheaper (https://www.dustin.se/product/5011304324/vengeance)
