RM1000X PCIe cable help
Solved by Poinkachu,
7 minutes ago, RayRsom said:So I can plug in 2 of the PCIe cables but I'm only using one connector of each of the 2 dual cables or do I use 3, I'm confused
You can go either :
3 separate PCIE cables, using just 1 8pins connector on each cable (the main), leaving the daisy-chained connector on each cable unused.
or
1 PCIE cable with both the main & daisy-chained 8pins connector, plus 1 more PCIE cable with just the main 8pins connector.
