graphic card power limit locked
Solved by Blai5e,
@RandomNeedsHelp - Why is the memory reporting 7001MHz? Shouldn't it read 1750MHz by default? If I were you, I'd DDU the driver, uninstall MSI Afterburner and start again with fresh downloads.
Scenario 1: Card is in "safe" mode. You may be having an issue with a PCIE riser/ motherboard PCIE slot or your power cables. You could try reseating the card and/or reseating your power cables.
Scenario 2: (Less likely) As you have a waterblock installed on the card, it could be mounting pressure (this is known to keep the GPU clock around 400MHz) but as you have had the block on for a while, I doubt this is likely.
