I keep having ram issues with a freshly built pc
21 minutes ago, Spoxe said:I recently built a pc with
MSI MAG B550 Tomahawk
AMD Ryzen 7 5700x
Corsair vengance LPX 2x16 3600 ddr4
2TB Samsung 970 evo plus
Some RTX 3060
after finishing the build and setting the bios up i got a bsod during the windows installation. I then launched memtest86 and saw multiple ram issues. After buying new ram ( G.SKILL Aegis 2x16 ddr4 3200) it worked fine for a few days, then programms started to crash and later windows had a permanent bsod. Memtest86 showed ram issues again. I suspect that I may have damaged the motherboard during the build but i dont want to waste any more money and effort if that doesnt work / there is an easier solution. Has anyone else ever encountered such an issue and can help?
Does it pass memtest when XMP (docp) is off?
Are you using the latest Bios?
Btw, the memory controller is on the CPU, not the motherboard. If you've bent a pin or two, there could be such issues.
