i3-13100 running at 4.3 Ghz rather than advertised boost freq of 4.5
Solved by unclewebb,
10 minutes ago, yazzmatazz said:Turbo Ratio Limits - IA/SSE: 45x (1-2c), 43x (3-4c)
It tells you in the log file you posted.
45 multiplier when 1 or 2 cores are active and the maximum multiplier decreases to 43 when 3 or 4 cores are active.
The core C states need to be enabled in the BIOS so this CPU can use the 45 multiplier when it is lightly loaded.
