38 minutes ago, DASADAS said:
Tried to undervolt my cpu even followed a guide on YT but the bios was diffrent so i think i fucked up cant start my computer at all anyway to fix it without buying a new cpu?
Tried CMOS reset yet??
Refresh before you reply
https://linustechtips.com/topic/1571482-help/#findComment-16419788
1 hour ago, DASADAS said:
Is that the right battery for cmos?
Yes. AFAIK there is still just 1 coin-type battery on motherboard up to this day, which is for CMOS
Not a sarcasm btw, just sharing what I know.
Sorry for the late reply too, was driving @_@
edit :
I see in your other thread that you have the problem solved by doing CMOS reset, glad it worked for you. 🙂
Edited by Poinkachu
https://linustechtips.com/topic/1571482-help/#findComment-16419887
