Help deciding on a power supply.
16 minutes ago, ChaosEmperor said:Budget (including currency): /
Country: Serbia
Games, programs or workloads that it will be used for: 3DS Max, V-ray, Blender
Hello guys, i have a quick question that i need help with, namely my Friend is building a workstation PC, he will mostly do 3ds Max video rendering focused mostly around CPU rendering on Ryzen 9 7950X and Gpu is gonna be 4070 Ti, no overclocking, full stock, for CPU cooler we went with Noctua NH-D15 as it is the beefiest option available here, and i am not a fan of AIO coolers as system will be rendering files almost constantly (close to 24/7).
My question is, what power supply is enough for this build? I have my eyes on: Seasonic Focus GX-850 80 Plus Gold 850W, will that be enough?
Thanks in advance and best wishes!
Yeah that will be plenty I run a 750w on 7700x - 32GB DDR5 and overclocked RTX 4080. Check the PSU Tier List for PSU's. For your system you should stay in the A tier.
The Focus GX 850w is A tier.
