Advice for first time SSF Build
1 hour ago, chilli-macaw said:Budget (including currency): 1500€(or 1500$)
Country: Germany
Games, programs or workloads that it will be used for: allrounder not just games.
I want to Build a SSF PC but i want it to be kind of quiet and that seems to not be easy.
I don't know why would you want a SSF PC but then that PC be super loud ... .
I have looked at a couple of cases for example The Ridge vom Fractal.
But a common problem seems to be no support for AIO and GPU so i was wondering what CPU to max out at to have quit-ish air cooling or a some good case recommendations.
I'm fine if the GPU ends up in the Midrange (6700xt or future 7600xt or 4060ti etc) or the PC ends up cheaper.
Hello, You can have a small PC Case that's not an ITX Case. The Case I have picked is the ASUS AP201. It's just a tad bit bigger than a ITX Case. It is a Full Mesh Case and I have added 2 Fan Packs of Be Quiet! Fans so that they are Silent and help move Air around the Case. 2 Fans for the top of the Case, 2 for the bottom, and 1 for the rear of the Case for a total of 6 fans. Also the CPU Cooler is also Be Quiet! so that is Silent too. If your lucky you just might only hear a whisper of air moving.
I have been building PCs for 30 years so if you have any questions please ask.
https://de.pcpartpicker.com/list/sm7T8r
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor (€174.73 @ Amazon Deutschland)
CPU Cooler: be quiet! Dark Rock 4 CPU Cooler (€67.67 @ Amazon Deutschland)
Motherboard: Asus TUF GAMING B550M-PLUS WIFI II Micro ATX AM4 Motherboard (€164.12 @ Amazon Deutschland)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory (€134.79 @ Amazon Deutschland)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (€54.90 @ Amazon Deutschland)
Storage: Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (€139.99 @ Amazon Deutschland)
Video Card: Asus ROG STRIX GAMING OC Radeon RX 6750 XT 12 GB Video Card (€329.90 @ Amazon Deutschland)
Case: Asus Prime AP201 MicroATX Mini Tower Case (€143.03 @ Amazon Deutschland)
Power Supply: Thermaltake Toughpower GF1 PE 850 W 80+ Gold Certified Fully Modular ATX Power Supply (€159.71 @ Amazon Deutschland)
Case Fan: be quiet! Light Wings PWM 41.51 CFM 120 mm Fans 3-Pack (€62.90 @ Amazon Deutschland)
Total: €1494.64
