Current Build - Thoughts on RTX Upgrade?
FIXD IT
Not even sure why I'm doing this at this point - I have no time to game, but I see the GPU prices collapsing thanks to Crypto taking a bath + a downturned economy.
I currently run an i7 10900k + GTX 1660S combo. Is it a waste to go 3070 or 4070 when it comes to bottlenecks, in your opinions? I primarily use it for graphic and web design renders for my computer repair business lately.
Any insight would be appreciated. Other specs include:
32GB of DDR4 Ram (3200MHz)
About 12 HDD's. I have a problem.
Appreciate any feedback,
Adam @FIXD IT
Does your software use GPU in a significant performance affecting way that is slowing you down? If yes, an upgrade will help. Otherwise, no point.
Gaming system: R7 7800X3D, Asus ROG Strix B650E-F Gaming Wifi, Thermalright Phantom Spirit 120 SE ARGB, Corsair Vengeance 2x 32GB 6000C30, RTX 4070, MSI MPG A850G, Fractal Design North, Samsung 990 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
Productivity system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, 64GB ram (mixed), RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, random 1080p + 720p displays.
Adam @FIXD IT
Hi there,
A 1660S to 3070 isn't a huge jump in power but the 3070 is faster. Going to a 4070 is a bigger power jump and you would notice that, the 1660S is a great GPU but then the 4070 is far greater.
The i7 is a bottleneck especially for 4080.
Core i9-10900K and GeForce RTX 3080
PC Builds
https://pc-builds.com › result › general-tasks
This configuration has 27.8% of processor bottleneck .
That's an example of a bottleneck to 3080, 4080 will be higher.
Bit of a tech guy, converted to PC's when consoles did not entertain me enough, the last console being an Xbox, was fun with Halo multi-play though. But  the want to discover, to test, to learn more about computers drove me to levels I had never known...
Some GPU's I have had, 8800GTS 384MB, 7800GT, GEFORCE 4 MX440, 250GTS,  770 GTX, 1650 GTX, RTX 3050 Plus many other GPU's over the years...
The respect I have for LMG is massive like a black hole, sucking in all the knowledge, I watch their awesome video's, their knowledge is like that of a God. Seriously some say they are number 1 in the whole wide world. LMG is like the INTEL fabrication plant. Beaming with technology goodness...
For the price really consider AMD the 6800xt are a really good deal , even the 6950xt you can get new for really good prices, in the UK its 650 for the best AIB
