SFF air-conditioning unit?
you will have massive inefficiencies transfering heat through so many mediums.
Like water block into water into radiator into air into evaporator into refrigerant into condenser into air.
way too many steps. The most ideal method is phase change directly to the cpu block. but this can be a bit too ideal very rapidly and cause moisture.
The next best thing is chilling the liquid.
Even the most perfect phase change cooling solution will expense a lot of energy. It is best to toss most of it outdoors.
you are ultimately better off air conditioning the room entirely since due to efficiency in heat pumps being weird, it will cost almost the same in both energy bills and buy/install price.
actually an idea I just had that you might like is to mod a window unit.
take it apart and put a apropriately sized rad directly in front of the evaporator so it gets hit with the full force of the a/c and the rest is exhausted out into the room.
It will use the a/c unit's fan, no need for additional rad fans. just a couple of quick connects and you can drop it in for the summer and hook up the pc into it. seems like a good setup to me.
