looks good just dont use a haf its ugly get something nice like a h440 or a 750d for even better rad support but thats just me being picky
Specs
https://linustechtips.com/topic/150219-a-build-plan/#findComment-2007727
i know its not the best case but i quite like it and are the wc parts ok im only 13 and im not too sure
i put a 290 in instead good point @Tea1337
and it will have the asrock z97 extreme4
so good?
My Setup :P
Skylake: I7-6700|MSI B150 GAMING M3|16GB GSKILL RIPJAWS V|R9 280X (WILL BE 1070)|CRUCIAL MX300 + WD BLACK 1TB
https://linustechtips.com/topic/150219-a-build-plan/#findComment-2007730
The stacker can take 3x360 and a 240
 CPU: i5-6600k MOBO: ASUS Z170 Pro Gaming RAM: G.Skill 16GB 2800Mhz 15-15-15-35, GPU: Sapphire R9 290 SSD: Samsung 840 250GB HDD: Seagate Barracuda 2TB x2, Cooling: EK supremecy EVO ,EK-FC R9 290X with backplate, XSPC EX240 Crossflow & Alphacool UT60 240mm, XSPC D5 Bayres w/ Alphacool VPP655, 7/16-5/8 Compressions/Tubing, Noctua NF-F12 x4 PSU: Silverstone Strider Plus 850W Case: Nanoxia Deep Silence 1 http://valid.x86.fr/8g2m02
https://linustechtips.com/topic/150219-a-build-plan/#findComment-2009886
@Lays you have a wc setup is this good?
sec lemme read through it and I'll post after.
https://linustechtips.com/topic/150219-a-build-plan/#findComment-2010137
Looks good to me.
Do get a 290, or 290X if you can like you said before.
https://linustechtips.com/topic/150219-a-build-plan/#findComment-2010152
Looks good to me.
thanks hopefully i will build a build like this when im older, just getting my bearings with wcing
My Setup :P
https://linustechtips.com/topic/150219-a-build-plan/#findComment-2012996
@Prokart2000 if you got the haf935 it has space for 3x120mm on the top and also 3x120mm in the front but you will have to remove the HDD cage
https://linustechtips.com/topic/150219-a-build-plan/#findComment-2013644
i was having them in the bottom as it will look less cluttered and more sexy with just the pipes and wires
after you saying this i added another 360mm to the build o put at the top
@Lays so you reccomend anything else or different
anyone whohas a watercooled pc could you suggest anything?
do i need fittings or a gpu bridge for the water to flow through both gpus?
there are some fittings in thsi post that i like http://linustechtips.com/main/topic/137810-black-pearl-ice-watercooled-define-r4-in-progress/page-4 but what bridge should i have????? i think thats it after, i need tips for the tubing mostly
My Setup :P
https://linustechtips.com/topic/150219-a-build-plan/#findComment-2013651
Tubes: http://www.frozencpu.com/products/17587/ex-tub-1575/PrimoChill_PrimoFlex_Advanced_LRT_Tubing_38ID_x_58_OD_-_10ft_Retail_Pack_-_Clear_PFLEXA10-58.html
Pump: Some variation of this like just a pump, or a res/pump combo
Fittings: Any color of these (Straight, 30°, 45°, 90°)
EK makes good blocks for CPU's and GPU's. Also i recommend for like $10 more going for the blocks with Nickel in them (Helps reduce corrosion)
Res: http://www.frozencpu.com/products/9575/ex-res-156/Bitspower_Water_Tank_Z-Multi_150_Inline_Reservoir_BP-WTZM150P-BK.html
Get a bridge that is the same brand as your waterblock
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/150219-a-build-plan/#findComment-2015250
ive got some blocks already check them out are they ok and dont you need a bridge
My Setup :P
https://linustechtips.com/topic/150219-a-build-plan/#findComment-2015276
Wheres the block i cant find it and no you can just run a tube between the two GPU's or you can get a metal tube that will extend and compress to fit between the two.
| F@H STATS |
https://linustechtips.com/topic/150219-a-build-plan/#findComment-2015292
the bit that say gpu block rev2.0 nicel thats a block to cool the mofsets vrams and core right? unless you need a block aswell? sorry gpu block nickel do i need a seperate block aswell?
My Setup :P
https://linustechtips.com/topic/150219-a-build-plan/#findComment-2015577
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU:  Intel Core i7-4770K 3.5GHz Quad-Core Processor  (£235.99 @ Amazon UK)
Motherboard:  Gigabyte GA-Z87X-UD4H ATX LGA1150 Motherboard  (£123.44 @ Scan.co.uk)
Memory:  Kingston Fury Black Series 8GB (2 x 4GB) DDR3-1866 Memory  (£58.37 @ Dabs)
Memory:  Kingston Fury White Series 8GB (2 x 4GB) DDR3-1866 Memory  (£61.64 @ Dabs)
Storage:  Samsung 840 Pro Series 256GB 2.5" Solid State Disk  (£144.84 @ Amazon UK)
Storage:  Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (£41.23 @ Aria PC)
Video Card:  MSI Radeon R9 290X 4GB Video Card  (£419.05 @ Amazon UK)
Case:  NZXT H440 (White/Black) ATX Mid Tower Case  (£91.73 @ Scan.co.uk)
Power Supply:  EVGA SuperNOVA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  (£78.90 @ Scan.co.uk)
Operating System:  Microsoft Windows 8.1 (OEM) (64-bit)  (£83.33 @ Amazon UK)
Case Fan:  Corsair Air Series SP120 Quiet Edition (2-Pack) 37.9 CFM 120mm  Fans  (£19.95 @ Amazon UK)
Total: £1398.37
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-05-11 22:14 BST+0100)
Warning: If you want custom cables that are not extensions you'll want to get a Corsair or Seasonic PSU for best availability
Watercooling:
Tubing: Primochill Advanced LRT
Coolant: Distilled water or water+Mayhems concentrate
CPU Block: EK Supremacy Clean
GPU Block: EK 290x Block+Backplate
LED Strip: IceModz
Custom Cables: IceModz
Pump: EK D5 Vario
Rads: UT60 360 and UT60 240 (I think that's compatible with an H440)
If you want I'll link all the WC stuff.
https://linustechtips.com/topic/150219-a-build-plan/#findComment-2016198
Total: £1398.37
Watercooling:
LED Strip: IceModz
Custom Cables IceModz
Pump: EK D5 Vario
Rads: UT60 260 and UT60 240 (I think that's compatible with an H440)
linking the stuff could help :)
just to point out im in uk so i will be on at different times
also can it be the clear ones so you can see the coolant inside the blocks
My Setup :P
https://linustechtips.com/topic/150219-a-build-plan/#findComment-2020087
Yep, I'll link them when I get home.
https://linustechtips.com/topic/150219-a-build-plan/#findComment-2022635
Total: £1398.37
Watercooling:
LED Strip: IceModz
Pump: EK D5 Vario
if you check now all i need is the gpu bit and the pump and res
My Setup :P
https://linustechtips.com/topic/150219-a-build-plan/#findComment-2026919
https://linustechtips.com/topic/150219-a-build-plan/#findComment-2027005
My Setup :P
https://linustechtips.com/topic/150219-a-build-plan/#findComment-2032965
