Is this a good pc parts list? shooting for 2200-2500
Honey BUn
My dream pc build
ryzen 7700x - 350
amd 7900xtx red devil, from microcenter, try to find open box for 900 -1000
1000w 80 plus gold psu -180
msi b650 mag tomahawk wifi and am5 axt motherboard- 240
32gb 5600 ram- 150 but there is deal at micro center
samsung 980 pro 2tb- 135
lian li 011 dynamic case - 170-200
heat sink -$??
total- $2,255
Also looking for a good heatsink/aio recommendation
19 minutes ago, Honey BUn said:
ryzen 7700x - 350
Buy a 7700 or 7900 non x instead, they come with the wraith prism which is more than adequate for the stock 90w power limit and you can do abit more tuning over that, not much temp/freq scaling on zen4 so running at 95c vs 85c basically no diff, also <1.2v vcore so theres no issue pushing the temps to tjmax (and problably abit more than that). Though coolers like the thermalright burst assassin go for 28$ and the peerless assassin/phantom spirit 120 go for 35-45$ which are alot better than the prism, but that just means if you buy those instead of using the prism then the prism acts like a 10-20$ cashback when you sell it
What specific psu? Gigabyte UD-GM 1000w go for 130$ (no not the explosion hazard p-gm) which aside from useless on paper marketing garbage has no noticable irl difference than whatever 180$ psu that is
Solid board, though b650(m) aorus elite ax tends to be cheaper and has more usb ports
God awful unless were talking the bare minimum 5600c30 or 6000c32 bins
CL itself is next to useless for performance but low cl because hynix a die for 8000+ capability and effectively futureproofing your kit for the rest of the ddr5 generation, whereas the higher cl bins are likely to come with trash that wont clock over 7000 and warrant a replacement in 2-3 years when you upgrade cpu and find out the ram cant clock high enough
Thats a damn good deal on a 980 pro, but if you dont do r/w heavy stuff like high res video editing refrain from buying since that wont do anything for your game loading times, an 80$ dram ssd like the leven jpr700 would be better. Also dont pay attention to branding, its as useless as ram branding since all the components (flash, dram, controller, etc.) Are made by the same few companies, and if they (component manufacturers) made garbage then theyd be out of buisness already
Case is personal choice, if you really like the look theres nothing wrong with it assuming you have maxed out your pc spec and still have budget leftover. 7950x + 7900xtx should fit and still leave some budget after the optimizations i suggested if you wanna use this as more of a workstation rather than a gaming rig (7700/7800x3d would leave even more budget headroom)
iirc it doesnt come with fans and isnt a particularly good aircooling case since its made more for custom loops/aios, but that shouldnt matter that much and maybe youll lose 1 or 2c stuff you literally wont notice, honestly boggles my mind why ppl buy the fractal torrent for aircooling performance and not just aesthetics. Anything with decent airflow will perform good, anything with bad airflow just take the sidepanel off now its effectively an open bench and itll perform decently
43 minutes ago, Honey BUn said:
heat sink -$??
follow @Somerandomtechyboi's advice for the other parts but for the cooler if you go with a 7700 non x or 7900 non x all you really need is a thermalright peerless assassin 120 or the ak620 and you'll be golden
Message me on discord (bread8669) for more help
Current parts list
CPU: R5 5600 CPU Cooler: Stock
Mobo: Asrock B550M-ITX/ac
RAM: Vengeance LPX 2x8GB 3200mhz Cl16
SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB
GPU: MSI RTX 3060 Gaming X
Fans: 1x Noctua NF-P12 Redux, 1x Arctic P12, 1x Corsair LL120
PSU: NZXT SP-650M SFX-L PSU from H1
Monitor: Samsung WQHD 34 inch and 43 inch TV
Mouse: Logitech G203
Keyboard: Rii membrane keyboard
Damn this space can fit a 4090 (just kidding)
https://www.microcenter.com/product/5006208/amd-ryzen-7-7700x-raphael-am5,-g-skill-flare-x5-32gb-ddr5-6000-dual-channel,-cpu-ram-combo
 that is the deal they have going on where basically you get the ram for free, is this good ram or no? also is there any performance difference when it comes to the 7700x vs the 7700 non x or the 7900, i dont plan on doing any editing or anything of that sort, just gaming. I dont know what brand to go with when it comes to psu because i dont have much knowledge besides just make sure its 80 plus gold rated,
also another question, i know the red devil 7900xtx retails for 1100 which i found at microcenter they are 999, with open box ones at 899 but i noticed there are 2 red devil editions on microcenter, one for 1100, and one for 999 but i cant seem to find any difference between them?
https://www.microcenter.com/product/661653/powercolor-amd-radeon-rx-7900-xtx-red-devil-limited-edition-overclocked-triple-fan-24gb-gddr6-pcie-40-graphics-card?ob=1 this is the 999 one
https://www.microcenter.com/product/661857/powercolor-amd-radeon-rx-7900-xtx-red-devil-overclocked-triple-fan-24gb-gddr6-pcie-40-graphics-card this is the 1100 dollar one, thank you so much for your help.
ones open box, the other isn't. amazing how much gpus depreciate over such a short time
Current parts list
that ram is OK. Really not very good though. I would try and get a non x chip and some cl30 trident z neo though. Ryzen 7000 really favours smaller timings
Current parts list
go with an rm1000x. Its a good quiet psu that has never made any problems for many people afaik
Current parts list
Is there any specific one you recommend? I was just looking at it since I would basically be getting it for free.
G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory (F5-6000J3040F16GX2-RS5K) - PCPartPicker
Current parts list
maybe im just dumb, but it seems to me the one in the microcenter link and the one you just recommmended me have the same timings, 36,36,36,96?
they are 30 but they're not consistent, good point, i'll keep looking image.png.2a92d94cbc61bc06b2e109c68b4879f6.png
Current parts list
go for this ram with 30-36-36-76
CORSAIR Vengeance RGB 32GB (2 x 16GB) 288-Pin PC RAM DDR5 6000 (PC5 48000) Desktop Memory Model CMH32GX5M2B6000Z30K - Newegg.com
Current parts list
Oh for gods sake the amount of times ive said primaries dont matter that much for performance
Its all in the subtimings, theres a reason why i constantly give the CL does next to nothing reminder because it does next to nothing for performance aside from very minorly improving benchmark scores
Focus your damn efforts in trfc, trc trrd-l/s tfaw (1), alongside the same rank diff rank diff dimm tertiaries, also just max out trefi
Though i did not know that the other primaries differed so may have to pay attention to that if the looser primaries 6000c32 doesnt come with hynix a die
@RONOTHAN## just give em a short summary of the timings that matter cause i currently only have knowledge and not experience cause
  Reveal hidden contents
bro used a megamind meme lol 💀
Current parts list
Because i have no money yet
And idk which memes are still relevant
im already planning to buy a car before june 6 but like ill be spending like all my money on said car so the no money predicament still stands
Leaves about 1 month to recover financially and start doing computer oc shenanigans cause senior highschool gonna start in july
na it was just a joke didn't mean to offend you. Mb didn't know the context. Hope you get money to get your car
Current parts list
No did not take that as offence dw
Yea sometimes you cant tell when youve offended someone or not online =p
Car > computer for now cause i dont even use a desktop and i wanna finally get into cars and have the pride of driving my own at a very young age, though i wonder if all the cressidas with the 1g are autos cause thatd suck, but oh well if i dont just immedeatly 1/2jz swap ill just salvage a w57/58 somewhere and slap a hx35 knockoff on the thing cause i dont think ethanol exists here in indo =|
Though since my goal is 2000$ (so theres headroom for flipping more pcs and not spending it on a car) maybe ill finally get to play around with ddr4, i mean ryzen 5500 are like 90-100$ and have cezanne imc, just need to pair with a decent ram clocker maybe b350 tomahawk since the b450 tomahawk hwbot has a ram freq validation of >5000 last time i checked, also pci slots so i dont need to spend loads on a pcie debug card, though it seems like past the 600$ mark pc sales start slowing down alot cause thats 9 million idr and i think ppl feel threatened if the price is >10 million cause the damn number itself
that sounds like a good plan, hope it all goes smoothly and have a good day mate!
Current parts list
