Is an OLED monitor preferred over using an OLED TV as display?
22 minutes ago, filpo said:i agree, the response times, even if they're the same panels, are normally better on monitors
Kind of a moot point when it comes to OLED. All OLED displays are in the same ball park, as seen by the example below. (Included the fastest IPS monitor he measured for comparison to LCD) You're not going to notice the difference between 0.20 and 0.37 ms from the best to the "worst" OLED display.
And if this is about input lag: LG's TVs in the game picture mode have the same <1ms processing delay, which means they're competitive with monitors in terms of input lag. The LG C2 is only held back by refresh rate in this comparison, but still it's still better than all but one LCD monitor Hardware Unboxed has ever tested. So it's still top-tier.
Now to the real reasons why you would want a monitor instead of a TV:
- Typically more relaxed auto-dimming behaviour
- DisplayPort connectivity if you don't have an HDMI 2.1 GPU
- Anti burn-in warranty (depending on the model)
- Smaller size (TV's start at 42", if you want something smaller it's going to be a monitor)
- Higher refresh rates
- Screen coating (monitors are mostly matte, TV's glossy)
- Auto sleep mode (can be worked around with 3rd party software on an LG TV)
- You want a curved display
And a few reasons why you'd want a TV instead:
- Smart TV interface with remote
- Much more calibration and color control settings
- Screen coating (glossy can be a preference)
- Typically btter compatibility with consoles
- Better upscaling and image processing
- Bigger sizes
- Better value (LG's 42" and 48" TV's have been available for under $800 from time to time)
- Higher resolution (they're all 4K)
I personally have the C2 and it's a better "monitor" than any monitor i've had in the past.
