Well I had to upgrade from a i3-3220 to an FX-8320, give my i3 to my mom, and the FX stock is a bit loud. Taking this bad to my dorm would bother my roommate, and I really want to overclock it.
I had a 4.2 GHz overclock. <Max I was thinking about was around 4.5Ghz.
What cooler would be good? I have a about 40$ to play around with. I was looking at a Cooler Master Hyper 212 EVO.
Suggestions?
^^All over in this post
Specs: http://pcpartpicker.com/p/3H276
https://linustechtips.com/topic/150068-8320-cpu-fan-suggestions/
212 evos a great cooler and quite so it gets my vote
Specs
https://linustechtips.com/topic/150068-8320-cpu-fan-suggestions/#findComment-2005812
What case do you have?
https://linustechtips.com/topic/150068-8320-cpu-fan-suggestions/#findComment-2011855
I have a 212 evo for my 8350 and keeps it around 30 celcius, gaming is around 50 :)
So id get that, its pretty darn cheap aswell
CPU Intel i7-6700k | Motherboard ASUS Maximus Hero VIII | GPU MSI GTX 970 | RAM 16 GB Corsair Vengeance 3000Mhz | Cooling Noctua NH-D15 | Storage 240GB Crucial M500; 2TB Seagate Barracuda | PSU EVGA 850w | Case Phatek Enthoo Pro M Acrylic
https://linustechtips.com/topic/150068-8320-cpu-fan-suggestions/#findComment-2012820
If you only have $40 the 212 evo is pretty much the only option worth getting.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/150068-8320-cpu-fan-suggestions/#findComment-2013585
