[Help] Higher than expected refresh rate on Odyssey CRG9
Solved by SquintyG33Rs,
it's DP alternate mode. it doesn't use USB data transfer spec. it's probably DP 1.4 if you wanted to check what kind of speed it can do.
it doesn't need to support the thunderbolt extra stuff to be able to switch into DP mode.
gentlemanspot ·
Posted in Console Gaming0 -
1
Idkwhattodowithmylife ·
Posted in Graphics Cards5 -
4eyeguy ·
Posted in New Builds and Planning4 -
Gin N Rum 5454 ·
Posted in Programs, Apps and Websites3 -
