Laptop fan making motor sound and vibrating
Hello, so I have this laptop that is like 2 months old, the Dell Vostro 3405 and some days ago the fan started making a not very loud like motor sounds 'brrrrrr' and then now it got louder and makes the laptop vibrate even, where the fan its located, thoughts on this? about what could it be, etc. Thank you in advance, hope you can help me figure out whats happening, any extra info you could need you can ask me
The first thing I would try is spraying some compressed air on the fan to see if anything is stuck in there. May be a bad fan, who knows.
Also try reading through this to maybe change fan settings, it is entirely possible that it is just ramping up far too quickly.
https://www.dell.com/support/kbdoc/en-us/000132117/fan-noise-on-inspiron-xps-notebook-vostro-notebook-mobile-precision-latitude-systems
My PC Specs: (expand to view)
CPU: Intel Core i7-10700K - OC to 5 GHz All Cores
CPU Cooler: Corsair iCUE H115i RGB Pro XT (Front Mounted AIO)
Motherboard: Asus TUF GAMING Z490-PLUS (WI-FI)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600
Storage: Intel 665p 1 TB M.2-2280 NVME SSD (x2)
Video Card: Zotac RTX 3070 8 GB GAMING Twin Edge OC
Power Supply: Corsair RM850 (2019) 850 W 80+ Gold Certified Fully Modular
Case: Corsair 4000D Airflow
Case Fan 120mm: Noctua F12 PWM 54.97 CFM 120 mm (x1)
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x4)
Monitor Main: Asus VG278QR 27.0" 1920x1080 165 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
Mouse: SteelSeries Rival 600 Wired
Keyboard: SteelSeries Apex 5  – (Hybrid Blue Switch)
Headphones: SteelSeries Arctis 9X Wireless - Black
Speakers: Mackie CR3-X 3 Inch Speakers Pair
UPS: APC 1500VA UPS Battery Backup and Surge Protector
Idk i think it wasn't doing this sound when i first got it and also now even with it is not spinning fast it keeps doing that sound but quieter
my laptop used to have the same problem, ended up getting a new fan from ebay.
because it ended up breaking or what
