Seagate 5TB Drive showing up as 561GB
10 minutes ago, Captain_Reginald said:So upon further inspection, apparently the USB device I was using to read the hard drive doesn't support capacities that high. I've switched over to a newer one that sees the entire size of the drive, but now we have a new problem - all of the options to partition or do anything with the volume are grayed out in Disk Management. Trying to do the same thing with parted on Ubuntu Linux responds that /dev/sdc isn't a valid location - except I can see it in the list of disks... how does that make sense?
Any ideas for now I can get past all this? Did I break it by messing with the partition in a device that doesn't support it?
Alrighty, I solved it! Took some problem solving, but I was able to clean the drive with DiskPart in command prompt, create a new primary partition, and then format the drive as NTFS with Disk Management. Now the drive is showing up as blank with 4.54 TB of space in file explorer! Woohoo!
It was frustrating to have to go to so many different places for help and then put them all together, but it's definitely satisfying to solve an issue like this yourself. Thanks anyway, guys.
