CPU clock speed and tdp dropping while gaming.
I don't know whats happening but when i do gaming on my HP Pavilion gaming laptop, its CPU clock speed and TDP drops. I am facing a severe fps drop. I got a motherboard change, it fixed the problem for a while but now its happening again.  I tried undervolting the CPU. It fixed the problem but sometimes it happens again. Can someone provide a solution.
System Specs? CPU, RAM, GPU......
If you haven't already done so, install HWInfo. You can look at the various values in real-time or save a log file for a more detailed analysis.
What are the temps reading?
Are your fans spinning? What RPM? If they are reporting zero, check to see if there is fluff or some other obstruction that might be stopping them from spinning.
Try changing the Windows Power Management Profile (Balanced, High Performance......)
Without knowing more, it looks like your CPU is cooking and throttling.
Living Room PC - Thermaltake Tower 100 - Intel Core i7 8700k @ 5.1Ghz - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - EVGA GTX 1080ti - 256GB Samsung NVMe - Corsair AX650 PSU - CPU + GPU cooled with single EKWB Quantum Surface P120 Rad + Barrow 3-in-1 Block, Res & Pump.
Bedroom PC - Thermaltake Tower 500 - Intel Core i9 9900k @ 5Ghz -  MSI Meg Ace Z390 Mobo - 16GB Ram - Palit RTX 3080ti - 256GB Samsung NVMe - Corsair HX850i PSU - CPU + GPU cooled with triple EKWB 240 Rads + Corsair Hydro XD5 Pump / Res Combo
Extension PC - Lian Li o11 Dynamic - Intel Core i7 8086k @ 5.1Ghz -  Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - EVGA RTX 2080ti - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate
Living Room AV Setup 5.1.4 - Yamaha RX-A2060 - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C6V
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C1. Yamaha RX-V1700 - 5 x Monitor Audio C265s (2 Zones)
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2
CPU = Ryzen 5 5600H, RAM = 8 Gb, GPU = GTX 1650
CPU temp readings without undervolting = 95-96 degree C
fans are moving fine but loud.
CPU clock speed dropping from 4.2 GHz to 2.6 GHz or something while gaming and TDP is dropping from 30 something to 7 or 8
That looks a little toasty!
There's a line in HWInfo that lets you know if you are thermal throttling. I can't remember what the line is titled but the output is either yes or no. What is it reporting?
If it is temp related, is the laptop easily serviceable??? Can you remove the heatsink, fan and cpu to check there is sufficient thermal paste and the cooler is properly mounted?
Seems like thermal throttling, and TDP is not power draw.
That laptop has bad cooling design to begin with, so really I think the only way to do this is undervolt as much as you can, cooling pad, proper clean up every few months.
Not an expert, just bored at work. Please quote me or mention me if you would like me to see your reply. **may edit my posts a few times after posting**
CPU: Intel i5-12400
GPU: Asus TUF RX 6800 XT OC
Mobo: Asus Prime B660M-A D4 WIFI
RAM: Team Delta TUF Alliance 2x8GB DDR4 3200MHz CL16
SSD: Team MP33 1TB
PSU: MSI MPG A850GF
Case: Phanteks Eclipse P360A
Cooler: ID-Cooling SE-234 ARGB
OS: Windows 11 Pro
Pcpartpicker: https://pcpartpicker.com/list/wnxDfv
Displays: Samsung Odyssey G5 S32AG50 32" 1440p 165hz | AOC 27G2E 27" 1080p 144hz
Laptop: ROG Strix Scar III G531GU Intel i5-9300H GTX 1660Ti Mobile| OS: Windows 10 Home
Ah i didn't checked hwinfo....lemmi check for thermal throttling.
The laptop is in warranty till June. Should I contact the customer care?
If its thermal throttling too quickly after going under load then I would definitely get them to look at it under warranty.
Hopefully, you'll get someone on the support line who knows what 'thermal throttling' is so the engineer knows what to do.
Make sure they add detailed notes on what you've done to diagnose the issue.
C
C
Yeah the customer support is pretty bad.
Thanks for help dude.
You can check these both images.
It shows two reasons.
Hi buddy, yeh, both those are reporting that thermal limits have been reached so the CPU is throttling.
I'd get onto support and see what they can do.
The only other thing you could try to solve it yourself would be to get a can of compressed air / dust cleaner and give all the vents a dammed good skoosh. Might be a dust clog somewhere.
Good Luck
C
Good Luck
C
Okii
