Budget (including currency): $2000 NZD or reluctantly $3000 NZD
Country: NZ
Games, programs or workloads that it will be used for:    workstation,      Ableton live 11 suite with Ableton push       &     yea basically the simple stuff
Other details: fast ram, SSD, nvme, just fast basically, unique pc case maybe an infinity mirror case*... oh yea RGB if I can umm... yea I think that's all... oh yea high end if possible not required though & yea I cant thing of anything more. 🙂      stay safe!!!    (and reply! lol)        *like this:        the.webp.0e0334fc8691e1286afe34fecd5015eb.webp
https://linustechtips.com/topic/1495246-workstation-build/
youre about... 5 years too late. Theyre hard to find and when they do its at stupid pricing. As with almost all old In Win and Lian Li cases.
Also, is Australia fine to shop in New Zealand? I know both economies are insanely well interconnected so id love to know how feasible that is.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1495246-workstation-build/#findComment-15850543
Just now, techbox said:
I dont understand could you be more specific?
Sorry. I just mean is it possible or economically good for new zealanders to get goods from Australia and then ship it to New Zealand? Australia has a lot of great computer store and i know that under the current immigration law set new zealanders can go to Australia pretty freely with few exceptions.
https://linustechtips.com/topic/1495246-workstation-build/#findComment-15850553
Country: NZ
do u need more of a cpu or gpu? RAM would probably be 32gb and storage how much would you need?
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1495246-workstation-build/#findComment-15850554
umm... yea I guess so I haven't rly thawt about that that. u guess i could ship them from there or somin
https://linustechtips.com/topic/1495246-workstation-build/#findComment-15850557
um.... around 10 core CPU and a mi/good gpu and 2/3TB of SSD and a 500GB nvme card        oh yea and a goodish screen w/ HDMI NOT VGA cuz all iv had is VGA fore years urrrrrG i have it!!!  🙂
https://linustechtips.com/topic/1495246-workstation-build/#findComment-15850561
So no gaming right just music production?
Since I know new zealand prices are basically 4x those of the us I'll have to have a look on nz pc sites. Got a couple links?
Also you can no longer find these cases as they had terrible airflow and caused cooling issues which led to them not being bought much so they stopped existing
https://linustechtips.com/topic/1495246-workstation-build/#findComment-15850597
Looking at case options here in indo theres only the magnium gear neo qube 2 (random o11d copy) at 160$ so thanks for the buisness idea 🙂
besides even with the front blocked off you can still take air in from the side, top, and bottom, problably what that overpriced magnium gear case is doing (since its an o11d copy)
as for op go look up on yt on how to make an infinity mirror on any case, just make sure you got a case that has good airflow from the top, side, or bottom so its not a hotbox
https://linustechtips.com/topic/1495246-workstation-build/#findComment-15850634
For an infinity case I'm using an older version of the GameMax Abyss currently. Don't know what availability is like worldwide.
Edit: In UK it is not expensive but apart from the lighting it is an unremarkable case. Kinda average for the price point.
https://linustechtips.com/topic/1495246-workstation-build/#findComment-15850721
Given NZ prices bling has to be sacrificed for performance.
CPU: AMD Ryzen 5 7600X 4.7 GHz 6-Core Processor  ($448.95 @ Computer Lounge)
CPU Cooler: Deepcool AK620 68.99 CFM CPU Cooler  ($115.00 @ Computer Lounge)
Motherboard: Gigabyte B650M AORUS ELITE AX Micro ATX AM5 Motherboard  ($357.06 @ Paradigm PCs)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-5600 CL36 Memory  ($232.76 @ PB Technologies)
Storage: Samsung 970 Evo Plus 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($247.00 @ 1stWave Technologies)
Video Card: Asus DUAL OC Radeon RX 6500 XT 4 GB Video Card  ($299.00 @ Computer Lounge)
Case: Cooler Master TD300 Mesh MicroATX Mini Tower Case  ($129.00 @ PB Technologies)
Power Supply: Fractal Design Ion Gold 550 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.00 @ Computer Lounge)
Total: $1927.77
Generated by PCPartPicker 2023-03-21 02:02 NZDT+1300
https://linustechtips.com/topic/1495246-workstation-build/#findComment-15850767
Total: $1927.77
I could break my pc budget and do $3000NZD coz I wanted to get a Raspberrypi_4_B+ and a sinology NAS but a guess i could get Thows another time. 😞 but as long as the pc is good not 1 that will brake in like half an hour! il sacrifice the raspi and the nas 🙂     oh and I'm fine w/ another case I only Thaut that 1 coz it looked Prity cool but yea its fine if its another case!
https://linustechtips.com/topic/1495246-workstation-build/#findComment-15851463
a little tiny bit of gaming
https://linustechtips.com/topic/1495246-workstation-build/#findComment-15851513
