advice on buying a small laptop
You definitely want an IPS or OLED type display in a laptop for any photo/graphical work. OLED being the very best but also expensive. IPS being the upper midrange nowadays. TN and VA displays being the lowend cheap options and not good for photo work, especially TN.
You'll probably want a refurbished Lenovo Thinkpad with a 1920x1080 IPS display since you want budget. I would recommend the T480/T480s. They usually come with an 8th gen i5 or i7 CPU, 8GB-16GB of RAM, and of course you'll want an SSD instead of an HDD, as old style hard drives (HDD) are wayyy slower. The size of the SSD storage is up to you for your needs. The T480 and T480s are very plentiful under $400 USD on Ebay.
And the reason I recommend a Thinkpad first is because of the Thinkpad culture and strong community support if/when you need help. Other good laptop models are the Dell Latitude and HP Elitebook. They both compete with the Thinkpad and each other, but aren't as popular among nerds.
