Drops of frame when moving camera in games
3 hours ago, teambou said:good day , good evening
here is my issue:
when i'm in some games and decide to move the camera i get a delay between my action and the result. this isnt like input lag it happens strictly when in games.
my cpu and GPU arent even near 100% when this happens
the only thing that i have as an info is that for some reason in valorant when this bug happens my CPU latency shoots up to 240ms which causes the "lag" i'm guessing.
i'm guessing i've got a bottleneck somewhere but i've trouble figuring out where the problem come from? does anyone have an idea ?
my wild guess is that it comes from the ram but if i'm posting here it's because i'm not sure.
thanks in advance for all your help.
My specs are:
- Microsoft Windows 11 Professional (x64) Build 22623.1180
- GIGABYTE B450 AORUS PRO-CF bios : F61c date : 05/10/2021
- AMD Ryzen 7 2700X
- Corsair Vengeance RGB PRO 32 GO (4 x 8 GO) DDR4 DRAM 2 666 MHz C16
- NVIDIA GeForce RTX 2070 ( KFA2 GeForce RTX 2070 EX (1-Click OC) v2, 8 Go)
- Samsung SSD 970 EVO Plus 500GB boot drive
- Samsung SSD 970 EVO Plus 500GB storage drive (different drive)
- TOSHIBA DT01ACA100 2nd storage drive
- Cooler Master V1000, 1000W
NB : sorry for the English which may contain some errors
I agree with the answer mentioned here.
However, I'm guessing you don't want: "buy a new CPU" as the answer
So, here's some things you can try that may improve (not completely fix) the issue. Added Bonus: If you get a new CPU, these tips can still help!
#1: Update to the latest BIOS. I would link to the BIOS, but I'm having trouble verifying the exact Motherboard you have.
fTPM (which I see you need to have enabled since you're running Windows 11) and AMD BIOS have had long-standing issues with stuttering and latency. There's a good chance upgrading your BIOS won't make it any worse.
#2: Update to the latest Chipset Drivers
#3: While it may seem counterintuitive, if the above doesn't seem to help, try disabling low-latency options in the Nvidia drivers and/or game mode/hardware-accelerated GPU scheduling in Windows 11
#4: Completely close any programs you don't need (Discord, OBS, OneDrive, etc.). Disable every overlay that you can. NVidia overlay, Microsoft Game Bar overlay, etc. In your specific case, this may help because the CPU is likely running near max capacity and freeing cycles may help.
#5: Try whitelisting Valorant in your Anti-virus (and if you're using something besides Windows Security, try using Window Security instead and see if that improves anything
(taken from Your Firewall VS. VALORANT – VALORANT Support (riotgames.com))
