System won't POST when a specific HDD is plugged in
Go to solution Solved by snowfox99,
4 minutes ago, TylerD321 said:
Evidently 38 people have seen this so far!! I’m curious what the issue was though.
I looked at the BIOS update changelog for that MSI motherboard, and the most recent revision mentioned something about "fixed SATA definitions". Flashed that and I was good to go. Still odd that one specific drive tripped it up when three other identical ones didn't, but, whatever, I'm just happy my data is safe.
Got a bit of a bizarre one for ya, I have four Seagate Constellation 4TB drives that were part of a RAIDZ array in a server that just recently died. I put together a temporary system with an old FX8320 and MSI 970 Gaming board just to get the array going again and access its data.
One of the drives *really* doesn't seem to like this particular motherboard. With the problem drive plugged in, the system will power on, turn on the display, but only output a black screen with POST code A2 in the corner. According to Google that's a drive detection error, which nearly made me shit myself at first cause I thought one of my drives was dead.
However, the problem drive worked fine in the HP server, and as a troubleshooting step I plugged it into my main PC and it booted fine, Windows detected the drive and CrystalDiskInfo reported it as healthy.
The FX board posts fine with all three other drives, but absolutely will not get past A2 with that drive connected, even if it's the only storage device plugged in.
Any ideas?
Have you tried using different sata cable in that computer or a different port?
My PC Specs: (expand to view)
Main Gaming Machine
CPU: Intel Core i7-10700K - OC to 5 GHz All Cores
CPU Cooler: Corsair iCUE H115i RGB Pro XT (Front Mounted AIO)
Motherboard: Asus TUF GAMING Z490-PLUS (WI-FI)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600
Storage: Intel 665p 1 TB M.2-2280 NVME SSD (x2)
Video Card: Zotac RTX 3070 8 GB GAMING Twin Edge OC
Power Supply: Corsair RM850 850W
Case: Corsair 4000D Airflow
Case Fan 120mm: Noctua F12 PWM 54.97 CFM 120 mm (x1)
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x4)
Monitor Main: Asus VG278QR 27.0" 1920x1080 165 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
Yep, swapped around ports and cables, pulled the cable off another drive that was detected fine, and as soon as I boot with it plugged into the problem drive, same issue.
UPDATE: I'm an idiot, I fixed it, hopefully no one saw this post.
8 minutes ago, snowfox99 said:
EDIT: I'm an idiot, hopefully no one saw this post.
Main Gaming Machine
how did you see?
Dont forget to mark as solution if your question is answered
Note: My advice is amateur help/beginner troubleshooting, someone else can probably troubleshoot way better than me.
- I do have some experience, and I can use google pretty well. - Feel free to quote me I may respond soon.
Join team Red, my apprentice
STOP SIDING WITH NVIDIA
Setup:
Ryzen 7 5800X3DSapphire Nitro+ 7900XTX 24GB / ROG STRIX B550-F Gaming / Cooler Master ML360 Illusion CPU Cooler / EVGA SuperNova 850 G2 / Lian Li Dynamic Evo White Case / 2x16 GB Kingston FURY RAM / 2x 1TB Lexar 710 / iiYama 1440p 165HZ Montitor, iiYama 1080p 75Hz Monitor / Shure MV7 w/ Focusrite Scarlett Solo / GK61 Keyboard / Cooler Master MM712 (daily driver) Logitech G502-X (MMO mouse) / Soundcore Life Q20 w/ Arctis 3 w/ WF-1000XM3
CPU OC: -30 all cores @AutoGhz
GPU OC: 3Ghz Core 2750Mhz Memory w/ 25%W increase (460W)
