Trouble with 3080 and Riser Cable - No display, no way to enable GPU
14 minutes ago, IckenOodleOup said:I have not tried forcing PCIE gen 3 yet. I will try this once I verify the GPU-MOBO are working.
Just a heads up, some people have had issues with that riser since Alex changed suppliers for the riser. Some people can't get the 4.0 riser to work at 4.0 and have to go to 3.0... Might be easier than completely removing everything from the case to see that the GPU and motherboard are working correctly, then rebuilding the computer.
Edit:
Here's a link with Alex's take on it.
And since it's a ways down in the thread, here's a quote. Spoilered because it's long. This is from only a few days ago, 27 Jan....
QuoteThe other riser that @riba2233 mentioned was not available to us when we made the order, I didn’t know it existed as it was released later.
I've tested that riser on our own machines (for both work and gaming) and they are still running fine in Gen4 on our RTX 3080 & Strix motherboards. Moreover, I’ve seen that cable being labeled 4.0 and used in T1 and quite a lot. The supplier told me that as long as the equipment is of high quality (i.e. not PC gear from alibaba) the 4.0 signal will be achieved, which given our own tests, I believed. Also, comparing that cable to the older Gen3 cable…my PC wouldn’t even boot.
Still, seeing that some get this issue is frustrating, but as always equipment is always evolving. I’ve spoken with our riser supplier during the past days to investigate the issue and they showed me the new cable @riba2233 was talking about, it’s basically 2x the price of the previous model. Again I didn’t have this option when we started manufacturing, but with this cable the MJOLNIRs and riser upgrades would have been about $40 more expensive.
If you experience problems running PCIe 4.0 on the riser, you can switch it to 3.0 in BIOS with negligible performance loss. I’ve heard some think this is somehow worse than a Gen 3 riser, but that is categorically wrong. A Gen 3 wouldn’t even boot a 4.0 device.
Now I’m going to list all issues in the current batch, from most important to least:
1. Riser
2. Booster Cell fan header
- While this issue is easily fixed, just snap off the plastic guard, it is saddening because this supplier has manufactured our electronics without any issues for the past years. Other than the wrong header the electronics are beautiful. I don’t believe the supplier had bad intentions, the connectors are super similar and it’s not like one is cheaper than the other. Again, luckily it’s an easy fix.
3. Tear in O2 Panel mesh
- It seems that for some people, the sharp riser bag punctured the O2 mesh during shipping. We should have secured them better, some shipments seem to have very violent journeys.
4. Magnets falling off
- This is extremely irritating issue, because we doubled the number of magnets but didn’t improve our gluing skills. I should have insisted the factory show me how they glue them, because when I do it myself it’s permanent. In any case, once you glue them back with Loctite (I can’t believe this issue still persists since Kickstarter) they will never fall off again and your MJOLNIR will have a LOT tougher panels than any previous iteration. On a positive note it seems we fixed the gluing of the corner guards, not heard anyone say they have fallen off in the latest batch.
5. No manual for BORG
- We are working on the manual for BORG now. I wanted to get the BORGs shipped before Chinese new year, but that would mean once they arrive we would have not finished the manuals yet. I still stand by this decision, it’s better that you have the product first and the manual later then getting both after Chinese new year. Also, BORG is pretty easy to attach without a manual, so I though it would be better if people got them asap.
6. Wrong label on BORG package
- This is basically a non-issue, but it’s frustrating to me that it even happened (easily avoidable and a reason to never skip triple-checking your work). Once you take the product out of its package you’ll probably never see that package again.
Of course I wish none of these problems would have been in the new batch, and some of them could have been avoided (Booster Cell fan header, magnets, BORG label) if we investigated more, which we should have done. It makes me sad though that some people think I’m like some evil dude that goes around and lies to your face and tries to hide problems. There are a lot of things in the new batch that have been improved, like tighter panels gaps, better corner guards, double panel hold (if all magnets are there), etc. But everyone instead overemphasizes the issues (most of which are easily solved), I understand why this happens though…super expensive case and you expect everything to be perfect (which I would expect as well).
Last but not least, I have never stated that we make the cases in Sweden, never. We’ve looked into Swedish factories in the past but they don’t have the capabilities to produce precision extrusions at lower quantity (say below 10.000 units). Also, the anodizing was subpar and very limited vs our factory in China. I have said they are designed in Sweden and made in China. You can’t find me saying anything else, period.
