SOS - Please help me with my build!
 Share
Budget (including currency): $1864.16-$1871.06
Games, programs or workloads that it will be used for: Gaming, Recording, Editing, Etc. (eventually streaming)
So, I live in the United States, and need to get my system list together entirely. For context, I used a Desktop my dad has built that was used by my mom, and we never upgraded it. It is still in it's Nearly original state. Currently uses DDR3. He then got a 2010 Mac mini for me for Christmas and I've been using that since (what I am posting this on rn), and then he was like, "Get a set of parts together," to me and that as he gets the funds, he'll get them one at a time.
But all I've gotten was the case because it's been stuck in place since like 1-2 years. I finally got around to it and am stuck on the Storage. It currently costs around $1864.16-$1871.06 and will be used for Gaming, Recording, Editing and maybe Streaming like Twitch eventually. You want the Specs to help out, go wild but the SSDs in it are not gonna be final, since one is too expensive, and the other may not be the best for gaming, dunno. And if you wanna help any further in this matter, I'd also like some help with finding out if all the parts are compatible with each other.
I also have the Magic Mouse there for a reason and that's personal reasons 🙂 Don't make it too expensive tho. Anyway, here is the list.
https://pcpartpicker.com/list/8VmzTn
little mis matched.
1000 watt psu when you need 400?
Why use a CPU with integrated graphics if you are going to use a graphics card?
spend around $100 on PSU
https://www.newegg.com/corsair-rm750e-750-w/p/N82E16817139300?Item=N82E16817139300
Saves you 70$
$40 fantastic cooler
https://pcpartpicker.com/product/zyNxFT/thermalright-peerless-assassin-120-se-argb-6617-cfm-cpu-cooler-pa-120-se-argb
saves you 60$
upgrade the CPU $210
cost 80$ +
https://www.newegg.com/amd-ryzen-7-5700x-ryzen-7-5000-series/p/N82E16819113735
one 2tb ssd $180
https://www.newegg.com/corsair-2tb-mp600-pro-xt/p/N82E16820236813
cost +10$
net savings $40 and much better all around.,
You don't need a fancy liquid cooler for that CPU. Any air cooler will be fine, even the one it comes with.
If you're using dedicated graphics, get the regular 5600, not the 5600G. The 5600G doesn't support PCIe Gen 4, so pairing Gen4 storage with it is a waste of money.
You're buying way too much power supply. You can save money by getting a smaller one; even a 650 watt power supply is overkill for that machine.
Dell owns my soul.
Here's a much better build for the money:
PCPartPicker Part List: https://pcpartpicker.com/list/48Thcb
CPU: Intel Core i7-12700KF 3.6 GHz 12-Core Processor  ($276.99 @ Amazon)
CPU Cooler: Deepcool AK620 68.99 CFM CPU Cooler  ($64.98 @ Amazon)
Motherboard: Gigabyte Z790 UD AC ATX LGA1700 Motherboard  ($194.99 @ B&H)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory  ($136.99 @ Amazon)
Storage: Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($134.99 @ Newegg)
Video Card: Asus TUF GAMING GeForce RTX 4070 Ti 12 GB Video Card  ($799.99 @ ASUS)
Case: Fractal Design Focus G ATX Mid Tower Case  ($64.98 @ Newegg)
Power Supply: Enermax Revolution D.F. 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($114.99 @ Walmart)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($26.09 @ Newegg)
Custom: HDMI Switch SGEYR 5x1 HDMI Switcher 5 in 1 Out HDMI Switch Selector 5 Port Box with IR Remote Control HDMI 1.4 HDCP 1.4 Support 4K@30Hz Ultra HD 3D 2160P 1080P  ($29.99 @ Amazon)
Total: $1844.98
Generated by PCPartPicker 2023-02-05 22:21 EST-0500
Went with Intel for this build, as for the money it makes the most sense. If you are using it for productivity tasks as you say, this will be much better than the 5600G you chose. It has 12 Cores and 20 threads. Perfect for streaming or editing and fast P-Cores for Gaming.
Provided an acceptable cooler that should be just enough for the 12700KF.
Went with a modern Z790 motherboard that's packed with features. Has Wi-Fi and Bluetooth.
Having two separate NVMe drives is not really necessary. One NVMe that's 2TB will be fine. This is one of the best drives for the money right now.
Absolutely no reason why a 3060 is in an $1800 build, easily slotted in a 4070 Ti which is a beast for 1080p, 1440p, and even 4K gaming.
Wasn't clear in your OP if you already have the Cooler Master HAF XB EVO, if you do then the case choice doesn't matter. If you don't have it already and haven't purchased it yet, I think this is a better case with a 5.25" bay for your DVD drive.
A 1000W PSU is also not needed for this build, and especially not your previous build. This is a Tier A unit and provides plenty of power for all your components.
Not sure what the HDMI Switch is for, but left it alone. However, while I understand the Magic Mouse is preferential, it's not really designed to be used on Windows. I recommend getting a proper gaming mouse instead (might as well get a nice Mechanical Keyboard while you're at it too).
Also, I would opt for Windows 11 Pro with this build because it works better with 12th Gen Intel. You don't need a retail key, as you can get a $15-20 OEM key from a key reseller. If you need a link to one of those let me know. All you would have to do is create a bootable USB drive on another computer (really easy to do).
        Mentioned on 10/16/20    in  TechLinked @ (4:06)
      Mentioned on 10/21/20    in  TechLinked @ (1:22)
     Mentioned on 12/30/20    in  TechLinked @ (0:14)
    Mentioned on 12/30/20    in  TechLinked @ (2:17)
   Mentioned on 05/18/22    in  TechLinked @ (4:25)
  Mentioned on 05/20/22    in  TechLinked @ (0:13)
 Mentioned on 05/25/22    in  TechLinked @ (5:24)
Mentioned on 06/08/22    in  TechLinked @ (1:20)
Mentioned on 06/20/22    in  TechLinked @ (3:54)
Mentioned on 06/27/22    in  TechLinked @ (3:52)
Mentioned on 08/10/22    in  TechLinked @ (3:50)
Mentioned on 08/13/22    in  TechLinked @ (1:16)
Mentioned on 08/17/22    in  TechLinked @ (4:12)
Mentioned on 09/12/22    in  TechLinked @ (0:11)
Mentioned on 09/23/22    in  TechLinked @ (0:14)
Mentioned on 12/09/22    in   WAN Show @ (1:43)
Mentioned on 12/21/22    in  TechLinked @ (5:07)
Mentioned on 01/09/23    in  TechLinked @ (4:27)
Mentioned on 01/09/23    in  TechLinked @ (5:40)
   Mentioned on 01/13/23    in  WAN Show @ (1:47:04)
Mentioned on 01/13/23    in  TechLinked @ (6:06)
Currently Playing:
Just Cause 3
Eye of Providence (HP OMEN 17-ck1111nr)
CPU12th Gen Intel Core i7-12700H 14c/20t GPU: NVIDIA Geforce RTX 3060 Laptop GPU ~ GA106 Memory: 16GB DDR5 @4800MHz SSD: 1TB PCIe Gen4 NVMe M.2 (OS/Programs/Apps/Games) HDD1: WD Elements 4TB External (Backup/Additional Storage) Monitor: 17.3” Full HD (1080p) IPS Micro-Edge Anti-Glare Low Blue Light 144Hz Display Mouse: Artic White Roccat Kone XP Mouse Mat: Corsair MM350 Premium Headset: Corsair VØID Stereo Gaming Headset OS: Windows 11 Home 22H2
CPU: Intel Core i5-13600K 3.5 GHz 14-Core Processor  ($319.83 @ Amazon)
Motherboard: Asus PRIME Z790-P WIFI D4 ATX LGA1700 Motherboard  ($239.99 @ Newegg)
Memory: TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($65.98 @ Amazon)
Storage: TEAMGROUP MP33 PRO 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($112.99 @ Amazon)
Video Card: Asus Dual GeForce RTX 3060 V2 OC Edition GeForce RTX 3060 12GB 12 GB Video Card  ($389.99 @ Amazon)
Case: Cooler Master HAF XB EVO ATX Desktop Case  (Purchased For $0.00)
Power Supply: Thermaltake Toughpower GF1 PE 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Amazon)
Operating System: Microsoft Windows 11 Home Retail - Download 64-bit  ($139.00 @ Newegg)
Custom: Magic Mouse ($79.00)
Total: $1557.83
Generated by PCPartPicker 2023-02-05 21:59 EST-0500
 Share
