Hp omen 15 I need advice.
 Share
Hi, i own a gaming laptop, hp omen 15, upgraded to 16gb 3200mhz ram, 1660 nvidia.
The laptop gets charged with oem 200w charger.
Is it normal that the charger gets very hot, i can touch it, but its spiking hot.
I game with it plugged in.
My laptop reaches about 73c max.
Should i remove the internal battery, or is it a way to lower the temp?
 Share
