ALERT - Linus Tech Tips, Tech Quickie, Tech Linked Youtube Channels Hacked ×
Low CPU and GPU usage and low FPS
Shrikefire
 Share
Go to solution Solved by aledsav1,
have you set windows power options to high, and nvidia control panel power to high, check that there is no FPS cap in nvidia control panel and in game settings
The other issue you have is playing it on a 1080p monitor, you need a better res 1440p to then make use of your hardware better
you previous pc had lower end stuff so it used more of the cpu/gpu to display on the 1080p
make sure vsync etc is off but you need a better monitor for starts
I am not tech savvy in any way so I need help with my pc. I recently upgraded my pc to:
ryzen 9 5900x
Geforce RTX 4080 founders edition
b550 aorus pro ac
32gb 3200MHz RAM
1tb ssd
evga gt 1000w psu
nzxt kraken z63 water cooler
1080p 144hz 27in curved monitor
after upgrading i had some major performance issues that i was able to fix by updating my BIOS to the latest version, enabling XMP, and PBO, and updating graphics drivers. this fixed the majority of my problems, like getting around 90fps in apex legends on low graphics before i changed those settings. after those fixes, although my performance increased quite a bit, i am still getting some  performance setbacks (i noticed my previous ryzen 5 5600x and my rtx 2060 was performing better than my new upgraded rig in some games). when i was using the geforce experience overlay (idk how reliable it is) my GPU and CPU were only at around 15-20% usage each, even when on high graphics. i am confused at why my CPU and GPU are being held back and why i am not getting the performance i was expecting, even after overclocking my CPU with PBO. when watching benchmark videos i see lower end rigs get better performance than mine, and my rig doesn’t get close to others like it. what is weird is that after running UserBenckmark, it says both my CPU and GPU are performing better than expected and got outstanding scores. I have no idea how pc’s work beyond the basic assembly and function. i have looked all over the internet and can’t find anything to fix my problem, so maybe i’ll find something here.
edit: i am planning on upgrading to at least a 1440p monitor, but probably a 4k monitor. i am aware of the 1080p issue when the 4080 is made for 4k. the problem i was facing was the 4080 not even being able to get 144hz at 1080p when my 2060 could, which seemed strange.
Edited by Shrikefire
22 minutes ago, Shrikefire said:
ryzen 9 5900x
This is the issue, You bought a good 4K GPU for 1080p 144hz, and a CPU that is made for productivity instead of gaming.
4080 is a beast, 5900X is a meh CPU for gaming, the 3200MHZ RAM does not help either, should've gone with 5800X3D.
IDK if 4080s have issues such as 3080s-3090s, wheres 1080p performance is so bad due to insufficient CPU, but once the resolution is bumped up, the performance increases.
Try to render the game in 4K by enabling Nvidia's DSR in Nvidia control panel, see if the performance and CPU/GPU usage go up accordingly.
Not an expert, just bored at work. Please quote me or mention me if you would like me to see your reply. **may edit my posts a few times after posting**
CPU: Intel i5-12400
GPU: Asus TUF RX 6800 XT OC
Mobo: Asus Prime B660M-A D4 WIFI
RAM: Team Delta TUF Alliance 2x8GB DDR4 3200MHz CL16
SSD: Team MP33 1TB
PSU: MSI MPG A850GF
Case: Phanteks Eclipse P360A
Cooler: ID-Cooling SE-234 ARGB
OS: Windows 11 Pro
Pcpartpicker: https://pcpartpicker.com/list/wnxDfv
Displays: Samsung Odyssey G5 S32AG50 32" 1440p 165hz | AOC 27G2E 27" 1080p 144hz
Laptop: ROG Strix Scar III G531GU Intel i5-9300H GTX 1660Ti Mobile| OS: Windows 10 Home
What are your temperatures like? It might be that the PS is throttling if they are too high.
Do you have any "weird" software on your computer that might leech power?
Please tag me or use the "reply" function so I get a notification
"Don't worry, be happy"
Sure would be neat if there was something useful here, eh?
You won't like this. Here we go.
The Ryzen 9 5900X is two 5600X glued together. Same gaming performance, double productivity performance, same bottlenecking of stronger cards.
When the 4080 is heavily CPU bottlenecked it enters low power states in which the card is a lot weaker. So yes, it will perform terrible.
And there's no CPU on the market that could properly feed (without bottlenecking) the 4080 on 1080p.
Only solution for you is to get a 4K monitor. Or, at least 1440p and play on the highest available details.
Edit:
here's a nice video showcasing good examples of bottlenecking on 1080p
With the 5900X on 1080p, the 4080 will probably underperform an RTX 3060.
  • Main PC: AMD Ryzen 9 5900X - EK AIO 360 D-RGB - Arctic Cooling MX-4 - Asus Prime X570-P - 4x8GB DDR4 3200 HyperX Fury CL16 - Sapphire Pulse Radeon  RX 5700XT - 1TB Kingston Fury Renegade - 1TB ADATA SX 6000pro  - 512GB ADATA SU800 - 1TB Seagate Momentus 5400rpm 2.5" - SAMA Armor Gold 750W  - custom black ATX and EPS cables - Fractal Design Define R5 Blackout - Windows 11 x64 2022 - 3 Arctic Cooling P14 PWM PST - 2 Arctic Cooling P12 PWM PST
  • Peripherals: LG 32GK650F - Philips 226VL - Logitech G Pro X Superlight - White Shark Spartan X (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Asus Xonar U5 - Sennheiser HD 560s - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Laptop: Acer E5–575G-386R 15.6" 1080p (i3 6100U + 2x4GB DDR4 + GeForce 940MX + 256GB nVME) Win 10 Pro x64 22H1 - Logitech G305 + AAA Lithium battery
  • Networking: Asus RT-N18U - SpeedPort Plus - 35/7 Mbps vDSL - TP-Link TL-WA850RE - TP-Link 5-port 1Gbps switch
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Streaming/Server/Storage PC: AMD Ryzen 5 3600 - LC-Power LC-CC-120 - MSI B450 Tomahawk Max - 2x4GB ADATA 2666 DDR4 - 120GB Kingston V300 - Toshiba DT01ACA100 1TB - Toshiba DT01ACA200 2TB - 2x WD Green 2TB - Sapphire Pulse AMD Radeon R9 380X 4GB - 550W EVGA G3 SuperNova - Chieftec Giga DF-01B - Logitech G710+ - Roccat Kone Pure Military Desert strike - Logitech S-220
Thanks. as it turns out, windows had an update which for some reason reset my windows power options back to default and i fixed it again. performance has been outstanding and my pc is working way better now. thanks for the help.
Edit:
I’m a bit confused. i ended up figuring out my windows had reset the power option and changing it worked. when you say the 5900x has the same gaming performance as the 5600x, that doesn’t seem to be the case for me. since fixing the power issue, my CPU has been performing considerably better than my old 5600x. not only was i getting as much as 60+ more frames in certain games, but it was way more consistent and didn’t drop frames like my old CPU did, especially when recording. i guess that last part makes sense for the 5900x as i bought it partly to start recording and streaming. i also forgot to mention i will be upgrading to probably a 1440p, maybe 4k monitor soon so i was aware of the 1080p issue. thanks for your response though.
Glad you sorted it..I think the main point about the bad performance referred to in that topic is not really the processor being bad at all it is the monitors resolution that then gets more out of your components
 Share
