ALERT - Linus Tech Tips, Tech Quickie, Tech Linked Youtube Channels Hacked ×
I think I made a mistake
Go to solution Solved by 191x7,
10 minutes ago, Enosified said:
I understand. Thanks for the feedback.
My question was more regarding the compatibility with the motherboard.
As per the motherboard website: https://www.gigabyte.com/Motherboard/B650-AORUS-ELITE-AX-rev-1x/support#support-memsup
It would apparently not be supported
So I think I will just cancel the order on the ram and buy another one with a lower CL!
Appreciate the help!
It will work.
A few days ago I wrote in here regarding a build that I am doing.
I was just watching the video from JayzTwoCents and after buying all my parts I think I made a mistake.
I bought those sticks of RAM : https://www.amazon.de/gp/product/B0B62WL8MK/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Are they compatible with this motherboard with a Ryzen 7 7700X? If not, which one should I be buying?
https://www.amazon.de/gp/product/B0BJDXDWS9/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Thanks in advance!
Yes you need DDR5
The speed is optimal for AMD= 6000
However the CL is not great.=40
If not a huge difference in price look for CL 28 or CL30
The CL 40 will work fine, but it simple not optimal = might see less than 1% difference in test scores.
Just now, mdk777 said:
Yes you need DDR5
It will work.
  • Main PC: AMD Ryzen 9 5900X - EK AIO 360 D-RGB - Arctic Cooling MX-4 - Asus Prime X570-P - 4x8GB DDR4 3200 HyperX Fury CL16 - Sapphire Pulse Radeon  RX 5700XT - 1TB Kingston Fury Renegade - 1TB ADATA SX 6000pro  - 512GB ADATA SU800 - 1TB Seagate Momentus 5400rpm 2.5" - SAMA Armor Gold 750W  - custom black ATX and EPS cables - Fractal Design Define R5 Blackout - Windows 11 x64 2022 - 3 Arctic Cooling P14 PWM PST - 2 Arctic Cooling P12 PWM PST
  • Peripherals: LG 32GK650F - Philips 226VL - Logitech G Pro X Superlight - White Shark Spartan X (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Asus Xonar U5 - Sennheiser HD 560s - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Laptop: Acer E5–575G-386R 15.6" 1080p (i3 6100U + 2x4GB DDR4 + GeForce 940MX + 256GB nVME) Win 10 Pro x64 22H1 - Logitech G305 + AAA Lithium battery
  • Networking: Asus RT-N18U - SpeedPort Plus - 35/7 Mbps vDSL - TP-Link TL-WA850RE - TP-Link 5-port 1Gbps switch
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Streaming/Server/Storage PC: AMD Ryzen 5 3600 - LC-Power LC-CC-120 - MSI B450 Tomahawk Max - 2x4GB ADATA 2666 DDR4 - 120GB Kingston V300 - Toshiba DT01ACA100 1TB - Toshiba DT01ACA200 2TB - 2x WD Green 2TB - Sapphire Pulse AMD Radeon R9 380X 4GB - 550W EVGA G3 SuperNova - Chieftec Giga DF-01B - Logitech G710+ - Roccat Kone Pure Military Desert strike - Logitech S-220
5 minutes ago, 191x7 said:
It will work.
Oh. But why isn't it listed as supported on the motherboard website?
Sorry for the question, I am still quite new to understanding the requirements for DDR5 ram.
Is it just that I won't be able to run it at 6000?
MB manufacturers cannot possibly test every RAM. Even the approved one could change revisions without RAM being retested.
Not sure if it could be true, but I always suspect the RAM manufacturers listed could pay a fee to be listed since that helps them sell more. Same way Maytag dishwashers say they are designed for a specific detergent, even if any detergent works. Not sure, but wouldn't surprise me.
There are far to many memory kits for motherboard manufacturers to test all of them. Just because a kit doesn't appear on a QVL list does not mean it will not work.
If you check the motherboard specifications you will see a note that it  supports both EXPO and XMP for memory overclocking. So the modules should be able to work at advertised speeds.
I understand it better now. Thank You!
Indeed I get that they cannot test everything. I think I will just see it on during the build 😄
Thanks for the explanation
 Share
