MSI 4090 need help tweaking please
Solved by HumdrumPenguin,
5 hours ago, KIDKICK said:i watched the entire video but it mainly references the ryzen 5 models. which are the 2 models below mine.
are you saying the my processor needs upgraded?
Precisely. Change your 3700X for something newer ASAP. AMD 3D CPUs for 7000 series are coming out in February. I go for one of those. The downside is that you'll need DDR5 RAM and a new mobo. The 4090 generation gap is really big. There's no cutting corners for that GPU. You do need current CPUs to make good use of that, and even then there will be CPU bottlenecks at 4k depending on the title you play.
