What kit performs better(gear 1 vs higher MHz etc)
3600 Gear 1 is the fastest by far. Gear 2 has such a performance penalty that it doesn't start to perform better than 3600 Gear 1 bandwidth wise until you get into the range of 4400MT/s, and it never is able to overtake it in terms of latency. If you're doing something that uses a ton of memory bandwidth, say very large video renders, then Gear 2 at say 4800MT/s might be able to outperform 3800MT/s Gear 1 tight timings, but for a traditional gaming setup Gear 1 all the way.
Whether or not it's worth the upgrade is a different story. I'd argue it isn't and you're better off saving up for your next system upgrade rather than this RAM upgrade that you're realistically not going to notice the difference of.
8 minutes ago, Wildgg said:From what I've read 3600mhz will run fine on Gear 1
It's a little more complicated than that. It's usually fine, though Gigabyte's Z690 DDR4 memory topology is terrible, so 3600 CL16 Gear 1 with dual rank memory is about the limits of the board without doing some manual tuning. If this was any other board that speed would be trivial, but Gigabyte really screwed up their Z690 memory support.
