PC won't boot after reseating CPU. Does post
Solved by KingUnicorn,
Update:
I was tired and decided to take it to a tech at a store I trust. Took a whole day but they said the CPU is dead and the motherboard is dead as well. Both likely due to a short. I guess I just gotta be more careful and discharge static better. I really appreciate the time and all the solutions given. Guess it's time for an upgrade.
I guess now the real question is AMD or Intel?
Edit: marking this as the answer even though there wasn't any real solution other than replacing everything
