FIrst time builder, just need some advice picking parts
Solved by CyberneticTitan,
I think you'll get more out of your gaming experience if you drop the 5800X3D for something cheaper like a 5600 or 5700X. Then you can use the extra budget to get a 3060 Ti or even a 3070. I would also see what you have available second hand.
Not sure how much the Corsair RAM is, but I would wager you could probably save $10-20 on other similarly performing RAM.
The Crucial P3 is a good drive, but it is QLC, and is only PCI-E 3.0. See if you can fit a decent PCI-E 4.0 TLC SSD like the Kingston KC3000, WD SN850X, Samsung 980 Pro, etc.
You don't need a Titanium rated PSU. You can probably save a pretty penny going to a 750W Gold PSU, something like a Corsair RM750/RM750X or Seasonic Prime 750.
