thermal paste Can thermal paste in cpu pins or Mobo makes PC act wierd even if it's not conductive?
Solved by Bartholomew,
Yes it can.
Since it's non conductive, it can prevent proper contact if in-between the cpu and the socket for one or more pins for example.
To much paste "on top" of the ihs, or even splattered around the pcb is OK. But not on sockets (cpu, ram dimms) or connectors; that can prevent contact et-all, or form a resistor or even some slight capacitance etc. That can do bad / weird things to signals.
