Battlefield 4 problems with SLI
Solved by MadManMarsBar,
1. make sure both cards work on their separately
2 re-install drivers ,
3 if its still laggy there is a BF4 SLi 'fix floating about here : http://battlelog.battlefield.com/bf3/forum/threadview/2955065670145885303/ , when i went from 1x 660 too 2x 660's i saw really bad stuttering but since i did this fix i only stutter for about 15 seconds at the start of a match and than after that its a solid 60 FPS on ultra settings
Hope this helped
EDIT : this link should help too : https://forums.geforce.com/default/topic/618930/battlefield-4-sli-fix/
