How to hook up RCA sub to LFE reciever?
By
Avocheeseado
in Audio
in Audio
Solved by cmndr,
Assuming the RCA cable isn't defective it should be the same as a proper "coax" cable other than that it won't be as well shielded. It's just a piece of wire with some rubber over it. Nothing special.
Make sure your AVR is set up properly, if it's in PURE mode for example there's no sub output.
You actually need to run the calibration software again.
Featured Topics
CorruptVenom ·
Justbon321 ·
Posted in Troubleshooting0 -
3
Ozzieh_man ·
aqarwaen29 ·
2
1
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
