Best monitor for full usage of my system.
Solved by Stahlmann,
I'd suggest the Neo G7. It's an amazing HDR display and 4K has gotten pretty easy to run for current high-end cards like your 7900 XTX. And at 32" the difference between 1440p and 4K is huge. The G8 4K 240Hz monitor shows scanline problems at 240Hz, plus you probably won't run games at 240 fps either way. So i wouldn't buy that one.
Since you're also using the monitor for work I suggest you stay away form OLED for burn-in reasons.
