MSI RTX 4090 Gaming X Trio does not run PCIe x16 (keeps running x8)
Solved by Codehack,
I've fixed the problem.
For anyone that has the same issue, the problem in my case was the CPU. My CPU cooler was apparently overpressing it and it resulted in bad contact with some pins. I figured this is the issue after I installed a contact frame and realized the cooler was overtightened. The card is identified as PCIe Gen 4 x16 correctly.
Featured Topics
7
AcidVinyl ·
Posted in Graphics Cards3 -
Phantasmagoria ·
Posted in Cooling2 -
BotherRed ·
Posted in General Discussion4 -
2
GOATWD ·
Posted in Operating Systems8
