Is 280mm AIO enough for 13700K?
ihsus
I am building a new gaming PC and I am planning to cool my i7-13700K with a 280mm AIO cooler. From what I have seen so far 13th gen intel CPUs can become very hot. Is this cooler going to be enough or could I possibly get more performance out of the CPU by getting the 360mm AIO?
I'd go with a 360mm AIO personally.  The 13700k is arguably the best gaming CPU for Intel, so in that vein I'd get the best cooling for the best chip.  It'll eek a little more out of it.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
A 280mm should be fine.
Depending on which brand you go to, some brand's 280mm AIOs perform better than other's 360mm. The difference is not that big, maybe 5°C at best. You can't go wrong with either, where you can go wrong is mounting them the wrong way. Have to be sure they are mounted right, to function properly for a long time.
| Ryzen 7 5800X3D | Arctic Liquid Freezer II 360 Rev 7| AsRock X570 Steel Legend |
| 4x16GB G.Skill Trident Z Neo 4000MHz CL16 | Sapphire Nitro+ RX 6900 XT | Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 2TB A-Data SX8200 Pro| Phanteks Eclipse G500A |
I am interested in either a 280 or 360 - for a 12700K, myself.   I am choosing between the Arctic Liquid Freezer AIO and Be Quiet (280 or 360) - probably leaning towards the Arctic 360 because the Be Quiet (in Germany/European market) is either hard to find or priced really high because of the high cost of importing parts from Europe (I assume).
I think these two - are pretty comparable - I also want a semi-quiet cooler/pump.   Lian Li Galahad and Corsair series AIOs are also intriguing but I don't think they perform better - and I dunno if they are as quiet - maybe close?
Tbh all well known AIOs have quite pumps. It's the fans that are usually the source of noise.
Ok.   Then get the 280 (2 x 140 fans) or the 360 (3 x 120 fans)? 🙂
With 360 AIO you get 2 thigs as a bonus. First is the bigger size of the rad, meaning more mass and more thermal capacity. 2nd is the increased airflow thanks to the more fans working on a bigger area. Generally the bigger the rad, the lower the RPMs needed to cool the liquid, because it has more time (space) to cool down as it travels though the rad.
280/360 will be more than enough just make sure to get a Z board so u can do a proper undervolt,
I got a 13600k with a 240 Aio, at stock it hits 100c p95 and r23 within 5 mins
undervolted to 1.15v from 1.38v underload and now I peak temp at 70c so have some oc head room now
but you would be able to do the same thing with the 13700k, get a good undervolt and it will be more than fine
-13600kf
- 4000 32gb ram
-4070ti super duper
  • 5 weeks later...
How do you undervolt?   Oh, you undervolt your cpu?
In the bios keep dropping the v core by 0.01v untill it crashes then put it up u till it’s stable. But realistically 1.17v should be stable for anyone on stock clocks and significantly reduce temps
-13600kf
- 4000 32gb ram
-4070ti super duper
